Floating Plinth Prototype
Re: Floating Plinth Prototype
Postby Doremi Fasol Latido » Mon Apr 07, 2014 12:51 pm
Miniature-Heroes wrote:Something like this?
Yeah, along those lines. Maybe play with the thickness and diameter of the acrylic a bit though to see what gives the best effect.
Doremi Fasol Latido
Postby blackfly » Mon Apr 07, 2014 3:54 pm
Miniature-Heroes wrote:Well the idea was to try and create the illusion of the top portion of the plinth 'floating' over the bottom.
I still don't get it. :)
I mean, floating desings, to me anyway, are there to suggest in-game or in-display floatyness. The plinth is not part of the figure's display environment, so setting it apart just doesn't make sense to me. Its a base, floating above another base, and on that second base is some art/craft/little doll. :?
Anyway, not trying to be a debbie downer, I imagine you know your market, and maybe plinth people are into this. It just doesn't make sense to me is all.
If its just a stylistic effect, I think it'd be more dramatic to have a different color wood in there, or polished metal, or something, just to class up the wooden cylinder. 8)
Can't connect to local MySQL server through socket '/tmp/mysql5.sock' (111) [2002]
"There should be a special term for people who join TMP* in order to complain about something** in their first post(s)." -AECurtis (RIP)
*FUUK
**TMP
blackfly
Postby Ace From Outer Space » Mon Apr 07, 2014 4:06 pm
The last picture you posted MH is much better, but I still don't think it works. I think the problem in part is that the top section is still too blocky. I think it would work better if both the top part and the bottom part were more organic in form, almost like two round flat pebbles (picture good skimming stones) sat one on top of the other. If they were wider and flatter you'd be less likely to see the join in between, making the top section appear to be floating. :)
Postby Skipp » Mon Apr 07, 2014 5:11 pm
blackfly wrote: maybe plinth people are into this.
There are plinth people? You really can learn something new every day...
Postby Big Jim » Mon Apr 07, 2014 5:33 pm
Mostly in Wales and have speech impediments, you must of heard of the Plinth or Plinthcess of Wales...
I'll get my coat.
Big Jim
Postby Miniature-Heroes » Mon Apr 07, 2014 6:13 pm
Thanks guys, feedback appreciated. I'll have a think and see what is possible to make them better.
Miniature-Heroes
Postby Skipp » Mon Apr 07, 2014 8:03 pm
I'll get my coat.
Yeah, I would :lol:
Postby blackfly » Mon Apr 07, 2014 8:17 pm
I'll get my coat.
:mrgreen: well done.
*FUUK
**TMP
blackfly
Postby Roger Theloger » Mon Apr 07, 2014 8:43 pm
I'm trying to think of a use.
Smaller clear block still.
Broader base for stability?
floaty rock?
Roger Theloger
Postby whiskey priest » Tue Apr 08, 2014 6:47 am
I was thinking that the main reason it doesn't look like it's floating in the first pick is because of the continuity between the two wooden parts. If you had a darker or different shaped bottom section, a matt black square block maybe an inch thick, and then the acrylic and circular wood it might give a better effect.
whiskey priest
Users browsing this forum: Majestic-12 [Bot] and 40 guests
